Hi everybody,
I am recording using rosbag record data from kinect inside bag files. Then I replay them, in order to extract RGB images, as shown in this tutorial : Exporting images.
I modified the extractor in order to have the synchronized extractions of multiple topics (here two kinects RGB). However I saw a problem :
When I replay the bag, sometimes the rosbag slows down : the count of duration that rosbag shows in the terminal freeze, and in the extraction, I don't have the same framerate (namely, it skips a lot of frames, and only take one on few).
Is there another way of extraction images from bag than "extract_images" from the package "image_view", for images of type sensors_msgs::Image ?
[EDIT] : maybe by using the rosbag API, and making queries inside the bag, in order to avoid missing images ?
Thank you in advance,
Bests,
Stéphane
Ps : I am using Ubuntu 12.10, with ROS Groovy.
Ps 2 : if someone feel the necessity to see the code, I will edit my question to include it.
Originally posted by Stephane.M on ROS Answers with karma: 1304 on 2013-06-11
This may be one starting point: http://answers.ros.org/question/10489/recording-video-from-the-pr2/ - a very small program to extract a video from a bag using the rosbag API and OpenCV.
Originally posted by DamienJadeDuff with karma: 399 on 2013-06-24
Comment by DamienJadeDuff on 2013-06-27:
To make that program work you may need to add cvReleaseVideoWriter(&writer); after all frames are written.
Comment by Stephane.M on 2013-06-27:
Ok thanks a lot, I'll have a look at it !
