I'm having a issue with the ROS RGBDSLAM installation in Fuerte. Whenever I run "roslaunch rgbdslam kinect+rgbdslam.launch" an empty RGBDSLAM GUI pops up. The terminal shows the error:
[ INFO] [1370907710.759761259]: No devices connected.... waiting for devices to be connected
even though I have the Kinect Xbox 360 connected and LibFreenect works fine. What am I doing wrong?
It appears to be an issue with OpenNI in particular, since when I run "roslaunch openni_launch openni.launch" the same error occurs.
Glancing at the source code in openni.launch and device.launch (in home/ros_workspace/rgbdslam_freiburg/rgbdslam/launch), I noticed that "depth_registered.launch" and "depth.launch" are referenced, but do not exist. Maybe that's the issue?
Ex, see code section:
<!-- Unregistered depth processing --> <include file="$(find openni_launch)/launch/includes/depth.launch"
       ns="$(arg depth)">
    <arg name="manager" value="$(arg manager)" />
    <arg name="bond" value="$(arg bond)" />   </include>
  <!-- Depth-to-RGB registration and processing -->   <include file="$(find openni_launch)/launch/includes/depth_registered.launch">
    <arg name="rgb" value="$(arg rgb)" />
    <arg name="depth" value="$(arg depth)" />
    <arg name="depth_registered" value="$(arg depth_registered)" />
Thank you!
Originally posted by rosslam on ROS Answers with karma: 1 on 2013-06-10
Comment by Felix Endres on 2013-06-11:
Your device is not found. I have seen reports that some drivers have problems with newer versions of the Xtion pro, maybe that holds true for your Kinect? Otherwise, have you tried a different USB port, preferrably a USB 2.0 port?
Comment by sai on 2013-06-11:
This issue arises for Asus xtion pro live devices and new version of microsoft kinect "kinect 4 windows"
Comment by Zayin on 2013-06-12:
If you have a Turtlebot and if your camera is draining power from your robot, make sure it's set to full mode on the dashboard. I have to do that every time I want to use openni + Kinect.
Hi,
You can find the installation steps to get the new kinect 4 windows working from these links
http://www.20papercups.net/programming/kinect-on-ubuntu-with-openni/
https://groups.google.com/forum/?fromgroups=#!msg/openni-dev/h0F6kYCNigs/BR6iqqFhSJ8J
http://mitchtech.net/ubuntu-kinect-openni-primesense/
Before these installation,
remove the old library files from ubuntu software center searching for libopenni.
after installation,
dont do rosdep install openni_launch.
directly do rosmake openni_launch and it should work.
Originally posted by sai with karma: 1935 on 2013-06-13
