I am following tutorial from microstrain_3dmgx2_imu/Tutorials/UsingTheIMUNode
Trying to get my 3DM-GX3-25 to work
When i rosdep install microstrain_3dmgx2_imu everything is fine
when I do rosmake microstrain_3dmgx2_imu I get
[rosmake-4] Starting >>> microstrain_3dmgx2_imu [ make ] [ rosmake ] All 2 lines {------------------------------------------------------------------------------- mkdir: cannot create directory `build': Permission denied
[ rosmake ] Output from build of package microstrain_3dmgx2_imu written to: [ rosmake ] /home/J/.ros/rosmake/rosmake_output-20130605-132831/microstrain_3dmgx2_imu/build_output.log [rosmake-4] Finished <<< microstrain_3dmgx2_imu [FAIL] [ 0.06 seconds ]
[ rosmake ] Halting due to failure in package microstrain_3dmgx2_imu. [ rosmake ] Waiting for other threads to complete. [ rosmake ] Results:
[ rosmake ] Built 38 packages with 1 failures.
When i tried to continue to the next step after plugging in the imu and typing ls -l /dev/ttyUSB0
I get ls: cannot access /dev/ttyUSB0: No such file or directory
Is my problem due to rosmake failing or is it the usb port problem or is it both?
I tried rosmake with root and it has no error but the directory is still not found o.O
I refered to the troubleshooting page for microstrain_3dmgx2_imu but my problem is not listed :(
Originally posted by Zoken on ROS Answers with karma: 16 on 2013-06-04
FIXED! i did sudo -s to rosmake microstrain_3dmgx2_imu with no errors then ls -l /dev/ttyACM0 instead of ls -l /dev/ttyUSB0 and everything work miracle
Originally posted by Zoken with karma: 16 on 2013-06-04
