Hi guys,
I'm trying to import my robotmodel on rviz but when I change the urdf file from
to a mesh (created by sketchup) like
when i run rviz the shell tell me
[ERROR] [1370333859.322282991]: Could not load resource [package://robo01.dae]: Unable to open file "package://robo01.dae". [ERROR] [1370333859.324037613]: Could not load model 'package://robo01.dae' for link 'base_link': OGRE EXCEPTION(6:FileNotFoundException): Cannot locate resource package://robo01.dae in resource group Autodetect or any other group. in ResourceGroupManager::openResource at /build/buildd/ogre-1.7.4/OgreMain/src/OgreResourceGroupManager.cpp (line 753)
following this post https://code.ros.org/gf/project/ros/mailman/?_forum_action=ForumMessageBrowse&thread_id=56835&action=ListThreads&mailman_id=20
i try
ls rospack find urdf_tutorial/robo01.dae
and it tell me that the file is in correct place (??).
Could someone tell me what I'm doing wrong?
thanks a lot guys for your answer
Originally posted by danielq on ROS Answers with karma: 181 on 2013-06-03
Hi @danielq,
You need to specify the actual package name and subdirectory (if any) in your URL. So try this:
If your model was in a subdirectory of the urdf_tutorial package called "meshes" (for example), you would use:
--patrick
Originally posted by Pi Robot with karma: 4046 on 2013-06-07
Comment by danielq on 2013-06-07:
thanks Patrick for the answer. It was soo simple soo it works.
Comment by Pi Robot on 2013-06-12:
Hi @danielq. Glad that did the trick. Please mark the answer as "correct" by clicking the checkmark above.
