I am currently having a problem with compiling Camera_Calibration_Parsers (error) for Groovy. I am working with an ARM processor and building from source. There isn't a libyaml-cpp-dev or yaml-cpp-dev binary available from apt-get so I am attempting an install from source. I have tried many ways on my own as well as trying to follow this.
I have also confirmed having the share libraries option selected for CMake.
Originally posted by orion on ROS Answers with karma: 213 on 2013-05-31
Check what version of yaml-cpp is installed in your system. If it's 0.5.0 you will have troubles compiling camera_calibration_paser. Try to downgrade to yaml-cpp to 0.3.0.
Originally posted by Artem with karma: 709 on 2013-06-01
Comment by orion on 2013-06-01:
There is a binary of yaml-cpp that is installable and does so when I try to apt-get camera_calibration_parser. It is 0.2.7. I have tried to install 0.2.5, 0.2.6, 0.2.7, 0.3.0, and 0.5.0 with no luck. In the process I did make sure to uninstall the apt-get version. There are no -dev versions.
Comment by orion on 2013-06-03:
Thanks for the help. Finally figured out what my simple issue was.
The solution I found was a combination of installing yaml-cpp-0.3.0 from source (which I already did) and removing the pre-built components of camera_calibration_parser (which I did not).
First, when installing yaml-cpp-0.3.0, make sure you open the configuration of the CMake file (i.e. run "ccmake .." in the build directory). Turn the option "BUILD_SHARED_LIBS" ON.
Second, navigate to the "build_isolated" folder under ros/groovy. Remove the camera_calibration_parser folder. Then you are safe to rebuild it.
As a note, the error was not only related to the "GetType" function. There were other times that different functions in yaml-cpp caused the error.
Hope this helps anyone who comes across this problem.
Originally posted by orion with karma: 213 on 2013-06-03
Comment by AndrewLawson on 2014-03-10:
Thanks so much, I was struggling with this issue and didn't think to remove the pre-built components!
