Can your ros_workspace folder be located on an NTFS file system?
I'm using ros electric and a wubi install of ubuntu 11.10.
I've added a new hard drive that I want both windows and linux to access, and I'd like to move my ros_workspace folder to the new hard drive. Unfortunately when I run my nodes from the new environment I get:
$ rosrun loader_testing boomPosCnt
[rosrun] Couldn't find executable named boomPosCnt below /media/may2013/ros_workspace/loader_testing [rosrun] Found the following, but they're either not files, [rosrun] or not executable: [rosrun] /media/may2013/ros_workspace/loader_testing/bin/boomPosCnt
When I switch the environment back to the old workspace in my home folder (ext4 file system) the nodes run fine. Thanks!
Originally posted by 4praytor on ROS Answers with karma: 5 on 2013-05-30
Comment by 4praytor on 2013-05-30:
Thanks mirzashah your idea worked!
I wound up following this post to remount the drive: http://ubuntuforums.org/showthread.php?t=1604251
This is a duplicate of another question: http://answers.ros.org/question/63952/ros-workspace-file-system/
Originally posted by mirzashah with karma: 1209 on 2013-05-30
