Does anybody has an idea of how to install the package wxpropgrid in groovy or if I need to treat it as an external library. And, how to manipulate the manifest and CmakeLists.txt files in case it must be treated as an external library.
Originally posted by acp on ROS Answers with karma: 556 on 2013-05-30
The ROS wrapped version of wxpropgrid seems to have been last released in Electric.
You will need to treat it as a system dependency. And add a rosdep dependency to your manifest. And make sure there's a rosdep definition for it.
Originally posted by tfoote with karma: 58457 on 2013-05-30
Comment by acp on 2013-05-30:
Hi, in advance thank you for your answer. However, would you mind giving me a more precise example of the things you are suggesting to do. I mean, How can I treat it as a system dependency, how do I add rosdep dependency in the manifest and how can I be sure there is a rosdep. In advance, thank you
Comment by tfoote on 2013-05-31:
The manifest is documented here: http://www.ros.org/wiki/Manifest
