I'm a neophyte of ROS programming: i need to use the same ROS-node for multiple independent agents; in other words i want to automatically replicate a node (during the launching), each one with its own ID. In addition i'd like to use this ID in each node in such a way that i can define a topic for each agent (node) using a string and an integer (ID) variable. can someone help me? thanks
Originally posted by mateo_7_7 on ROS Answers with karma: 90 on 2013-05-28
You can set the node name as a parameter when you run it. And you can use a local topic name, which will be relative to the node name.
http://wiki.ros.org/Names
Originally posted by tfoote with karma: 58457 on 2016-07-27
