Hi everyone!
I'm trying to print a statement on the command line and then get inputs (strings to be more specific) from the user while my package is running. I'm writing my node in Python. Is there anyway to do this? I now this seems trivial, but I'm new to ROS and couldn't find anything regarding this problem on the web.
Thanks.
P.s. I tried print '....' but it doesn't print anything on the command line. I tried n=raw_input() but my node crashes.
Originally posted by Behzad_a on ROS Answers with karma: 13 on 2013-05-27
Comment by askkvn on 2019-06-14:
Are you trying to run this python file with rosrun or with roslaunch?
As HenryW already said, you can use the normal python method, for example
#!/usr/bin/env python
from rospy import init_node, is_shutdown
if __name__ == '__main__':
  init_node('input_test')
  while not is_shutdown():
      print "gimme something, please?"
      something = raw_input()
      print "thanks for giving me " + something
compiling this node and then running it leads to
beer
thanks for giving me beer
box
thanks for giving me box
plant
thanks for giving me plant
If this doesn't work for you, update your question with your code and error messages.
Originally posted by goetz.marc with karma: 203 on 2013-05-28
Post score: 4
As far as I am aware, you can use standard Python methods for getting input from the keyboard when making your program.
Originally posted by HenryW with karma: 140 on 2013-05-28
