I've built an SCI-RS-232-USB cable for connecting to my Roomba using the following tutorial:
blog.makezine.com/2008/02/29/how-to-make-a-roomba-seri/
The cable works as I tested it on my Windows machine using the RealTerm Serial Terminal. I was able to make the roomba move and beep by sending raw opcodes. However it should be noted, I could only send packets if the RTS line was cleared, and only receive sensor packets if the RTS line was set.
I've tried to change the hardware and software control options in minicom to try to get a different response; no luck. Basic troubleshooting - disconnecting, power cycling, etc.
Any help to remedy the problem is appreciated!
Here is the necessary info from the USB-Serial interface
USB-Serial Permissions
dmesg | grep tty
[ 1.113447] tty tty34: hash matches
[ 1142.333506] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
ls -l /dev/ttyUSB0
crwxrwxrwx 1 root dialout 188, 0 May 26 18:19 /dev/ttyUSB0
Minicom configuration
A - Serial Device : /dev/ttyUSB0 |
| B - Lockfile Location : /var/lock |
| C - Callin Program : |
| D - Callout Program : |
| E - Bps/Par/Bits : 115200 8N1 |
| F - Hardware Flow Control : No |
| G - Software Flow Control : No
Rosrun Error
rosrun roomba_500_series roomba500_light_node
[ INFO] [1369617555.945517395]: Roomba for ROS 2.01
[FATAL] [1369617555.969045803]: Could not connect to Roomba.
[FATAL] [1369617555.969251975]: BREAKPOINT HIT
file = /home/trevor/catkin_ws/trunk/roomba_500_series/src/roomba500_lightweight.cpp
line=90
Trace/breakpoint trap (core dumped)
Originally posted by robbie.sharma on ROS Answers with karma: 1 on 2013-05-26
