This is a simple question about the ROS communication between nodes.
Only the node that advertises a topic can publish to it?
Originally posted by Median on ROS Answers with karma: 23 on 2013-05-26
Yes and no :-)
A node needs to create a publisher, which advertises a topic, in order to send anything. So "yes": a node can't send anything on a topic if it doesn't advertise it.
However, multiple nodes can advertise the same topic and publish on it (as well as multiple subscribers can listen). So "no": not only the first node that advertises a topic is allowed to publish on a given topic name.
Originally posted by Philip with karma: 990 on 2013-05-26
Comment by Median on 2013-05-26:
What that means is that multiple nodes may advertise the same ROS topic, is that right?
Comment by Philip on 2013-05-26:
Correct! Updated my answer to explicitly state that.
