Hi All,
I was fiddling my turtlebot today and I found something a bit surprising... It doesn't actually go in a straight line!!
I was running the .cpp script from turtlebot_teleop (yep, I made another package and built the script), and turtlebot moves in a arc... Unsure what is happening here and I tried running calibration and guess what, not just it doesn't work but my turtlebot actually goes backwards! lolz
I was trying to find something on the net but apparently no one else has this problem... Any ideas? Is there something wrong with my parameters or is hardware giving me a hard time? Let me know if you need any data/log/code/etc.
Cheers,
Mid
Hardware: turtlebot (the old type)
ROS version: electric
OS: Ubuntu 10.04
Originally posted by Midnight on ROS Answers with karma: 5 on 2013-05-23
It sounds like one of your motors has died. You can try sending commands directly to the base with twists to command the bot to drive straignt, turn in place right and turn in place left. If you need more help describe the behavior when sending different commands, both commanded and observed.
Based on the calibration driving backwards my guess is that your right wheel motor has failed.
Unfortunately, there's no good fix for that. Check to make sure that the wheels aren't bound on hair or other debris. And beyond that you may actually have a bad motor which will require you to go inside the Create and debug. Unfortunately the Creates are known to wear out over time.
Originally posted by tfoote with karma: 58457 on 2013-05-25
Comment by Midnight on 2013-05-26:
Hey Tully, thanks for the reply. Righto, I did some test and here what I found out:
Twist.linear.x = 1 => Forward and leftwards
Twist.angular.z = 1 => Rotates anti-clockwise while going forward and right
Twist.angular.z = -1 => Rotates clockwise while going back and right (0.o)
Thanks
Also, I wasn't able to take the wheel apart, since it doesn't belong to me. But from observation, I don't see any debris at all... Maybe suggest a way to debug, please?
Thanks again!
Comment by tfoote on 2013-05-26:
Unfortunately this seems to me to be a hardware problem. There's not much lower level you can go than sending raw twist commands.
Comment by Midnight on 2013-05-27:
Got it. I report on.
Thanks a lot =D
Comment by benabruzzo on 2017-09-10:
Does anyone know of a vendor or source for replacement wheel motors? I'm pretty sure I have a failed motor on a kabuki platform, but I have not been able to locate a replacement.
