Hello. I've got a problem with topic remapping. I have a node that publishes informations relative to a robot, and listens to the topics of the informations relative to other 3 robot of the same type. Something like:
publish on : /robot1/info listens to: /robot2/info , /robot3/info, /robot4/info.
Now I want all the 4 robots to share the same code.
So, I want, for example, robot2 to publish on /robot2/info and to listen to /robot1/info (and to the other 2 robots of course)
In the launch file a used a classic remap in this way: from="/robot1/info" to="/robot2/info" and from="/robot2/info" to="/robot1/info"
but the result is that nothing changes and I think is due to some kind of circular remapping.
Any idea of how to address the problem? Thank you in advance.
Originally posted by jacky_90 on ROS Answers with karma: 101 on 2013-05-23
I think you've identified the heart of the problem: you're trying to remap the output of a node to the same name as one of its inputs. Instead, try to leave each node's output alone, and only remap the inputs:
my_node:
  - publishes: infoOut
  - subscribes: infoIn1, infoIn2, infoIn3
<node name="node1" pkg="my_pkg" type="my_node" ns="robot1">
  <remap from="infoIn1" to="robot2/infoOut"/>
  <remap from="infoIn2" to="robot3/infoOut"/>
  <remap from="infoIn3" to="robot4/infoOut"/>
</node>
<node name="node2" pkg="my_pkg" type="my_node" ns="robot2">
  <remap from="infoIn1" to="robot1/infoOut"/>
</node>
Alternatively, if you don't want to put each node in a separate namespace, you can use the same approach as above, but remap each node's output into a node-specific name:
<remap from="infoOut" to="infoOut1"/>
Originally posted by Jeremy Zoss with karma: 4976 on 2013-05-23
Post score: 4
