I have an aerial image over an experimental area. What is the best way to show that image on the ground in rviz?
Originally posted by TommyP on ROS Answers with karma: 1339 on 2013-05-19
Comment by ayush_dewan on 2013-05-19:
Can u elaborate the question..
Comment by TommyP on 2013-05-19:
Well. Suppose I have an jpg image. How do I display it in the XY plane at X=0. I know that I can build an robot model and doing a mesh that uses the image as a texture and so on. But that seems to me to complicated... Especially since I cannot get mesh files with textures to work.
Comment by dgossow on 2013-05-19:
If it's grayscale, you could send it via an OccupancyGrid message and show it via the Map display.
Unfortunately I haven't seen such a DisplayType yet. Two ideas:
  1. Code it yourself if you stand Qt. Personally I'd try to merge the image-subscribing code from Image-DT into the visualizing code from Map-DT.
  2. If your image is nearly static, the overhead of converting it into a flat point cloud and transferring it might be insignificant. If your graphics can render that.
Originally posted by felix k with karma: 1650 on 2013-05-21
Comment by TommyP on 2013-05-21:
Well, I kind of like QT but wanted to avoid having to understand the 3D code... The flat point cloud idea seems nice. I think I will test that and see how it looks.
