I am trying to show meshes in rviz and the mesh is originally an OpenSceneGraph model (.osg). My previous conversion pipeline was to use osgconv to convert to 3ds and wings3d to convert to collada dae. That worked a couple of months ago but stopped working (nothing is displayed) in a recent update.
So do anybody have a working and recently tested conversion receipt for this only using Linux (Ubuntu)? Or any suggestion about what to test? I tested meshlab and got the object but no textures.
Originally posted by TommyP on ROS Answers with karma: 1339 on 2013-05-19
Do you mean this stopped working with a recent RViz update? There was a change in RViz that could cause this - it now interprets the 'unit' property in collada files. If this is set wrong, your meshes could be too large or too small to see in RViz. Check your collada files for that.
Originally posted by dgossow with karma: 1444 on 2013-05-19
Comment by TommyP on 2013-05-19:
Yes, it stopped working in a recent rviz update but I do not know exactly when. I will check the unit property.
Changing the unit definition of meter from 0.01 to 1.0 solved the problem with my old Collada files. The Wings3d export to Collada works OK. I am still interested in alternative conversion paths which could give nicer handling of material properties.
Comment by dgossow on 2013-05-19:
The tools you use have parameters that control the scaling, they should do the job without manual adjustments.
That means that I have to learn the tools... And I really thought my original format was unit less. So it was really a surprise for me that units are added in some formats.
