Hello
I would like to know the travel time for my robot when he move from one position to another. So for example I wont to know the time needed that my robot move 10 m forwards. So I have a map ov the environment and my platform has IMU, laser, Kinect and encoders. So I do not do any navigation just driving the platform for example 20 m forwards and wont to know the time needed to complete that task. Any help?
Thanks
Originally posted by Astronaut on ROS Answers with karma: 330 on 2013-05-14
Comment by dornhege on 2013-05-15:
Are you driving yourself by hand? In that case, you'd anyways have inaccuracies in the measurements and you can just use a stopwatch instead of software.
Comment by Astronaut on 2013-05-15:
I need a software ROS solution and not a stopwatch. So I need to know the time when platforms move from one position in the map to other.
Im not driving by my self. Im observing when someone else is driving it.
Comment by davinci on 2013-05-15:
You can read out the encoders to measure the travelled distance and run a timer in parallel?
the encoders are drifted. So maybe better to use the pose, How to run a ROS timer??
http://www.ros.org/wiki/roscpp/Overview/Timers
You can just use the system clock, and subtract the start time from the end time. In python
import time
start = time.clock()
# Do something
end = time.clock()
print end-start, 'seconds'
and in C++, use gettimeofday() or some similar function.
Originally posted by Bill Smart with karma: 1263 on 2013-05-15
