I'm looking to buy a micromouse (i.e. a small single-board unit with wheels and IR sensors that can move around freely). I've done a lot of searching but have only found resources relating to building one from components bought separately. However, I'm more of a programmer than an electrician so I fear I would struggle with this.
Anybody know where to buy one of these in the UK? (PICAXE does some suitable stuff but they're BASIC only unfortunately). My budget is about £60.
closed as primarily opinion-based by Ian, TobiasK, Shahbaz, Mark Booth Jan 21 '15 at 12:06
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
Try a Pololu 3Pi. They were going for 50usd during black friday. Normally $99. You can use arduino IDE to program it using Wiring, a C/C++ like language.
You would probably have to add IR sensors yourself, either via the expansion board, or re-wire the existing line detectors
At the moment, Hobby Robots are still only reachable by those with soldering skills. But that will be changing in the next few years.
3Pi
I think you'll be hard-pressed to find a Micromouse off the shelf besides PICAXE. If you want one that's a bit more advanced, I'd recommend putting the robot together yourself. I would encourage you to try out the electronics on a project like this, they aren't too bad to figure out and there are lots of resources online.
Some recommendations:
  • An arduino-nano is capable for such a task, look into AVR-GCC for programming.
  • NEMA-17 sized stepper motors will supply enough power, Pololu is a good site to find these motors and matching wheels/controllers.
  • I've seen people use Sharp IR's before, this will simplify some of the electronics.
This is a difficult project but very rewarding! Best of luck.
  • $\begingroup$ Might try building one then. There are indeed a lot of resources out there to help, but I have absolutely no experience with electronics so it's quite a scary thing to look into when most the articles I've read are very jargony and over-my-head technical. $\endgroup$ – Jazcash Dec 7 '14 at 19:25
