Hello everyone i am new to this group and ROS, and i am writing because I have a problem with the interface for the ROS arducopter and also wanted to better understand the things that I am not clear on this subject.
I'm writing my graduation thesis, and I'm working on quadrorotor automated using the ROS, in the beginning I focused on Parrot AR.Drone 2.0, but now now I'm focused dell'arducopter.
My setup is Ubuntu 12.04 and ROS Fuerte, I own an AR.Drone 2.0 but NOT own a arducopter.
The first problem is with the interface roscopter, I followed all the instructions on code.google.com/p/roscopter/
but when I go to run the command:
nodes / roscopter.py - device = / dev/ttyUSB1 - rate = 57600 - enable-control = true
I get the error: Traceback (most recent call last): File "nodes / roscopter.py", line 7, in import roscopter.msg File "/ home / joe / fuerte_workspace / roscopter / nodes / roscopter.py", line 7, in import roscopter.msg ImportError: No module named msg
The error is in the import roscopter.msg, and in fact inside the folder there is no msg file "roscopert.msg" I have to define it? in what way? how?
The second problem is that I have to figure out which topic should I write in order to execute the commands of TakeOff, Land, various movements etc ... For example, with the 2.0 ardrone to make a takeoff was enough to send a message "std_msgs / Empty" on the topic "/ ardrone / takeoff" with the command on the terminal of ubuntu: rostopic pub -1 / ardrone / takeoff std_msgs / Empty How does works for the roscopter?
Another thing that i want to figure is the role of MAVLink, and how does works .
Thank you very much in advance and sorry for my English
Originally posted by Giona Grancheli on ROS Answers with karma: 3 on 2013-05-09
It sounds to me like you didn't quite get the package built correctly. Inside of the roscopter_base/msg/ directory, you will find all of roscopter message definitions. If rosmake successfully builds the project, it should create a roscopter_base/msg_gen/ directory, and a roscopter_base/src/roscopter/ directory. These directories actually have the necessary code to use the messages in roscpp and rospy. If you don't have those directories (or the files that are supposed to be in them), you will encounter the error that you are seeing. Try running
rosmake roscopter
to (re)generate the necessary files.
Originally posted by jarvisschultz with karma: 9031 on 2013-05-09
