My computer's OS is Ubuntu 12.04 with Groovy and I am working with the source installation of ros moveit. To modify one of the moveit packages I tried to open a package in qtcreator (execute qt creator from console --> 'open project' --> op Cmakelists) to benefit from code completion etc. However, I am facing two issues:
  1. running cmake on package pr2_moveit_tutorials fails and I am receiving the following errors: CMake Error at CMakeLists.txt:3 (install): install TARGETS given no RUNTIME DESTINATION for executable target "planning_scene_tutorial". So far I circumvent this issue commenting out the 'target_link_library' lines in the Cmakelists. Perhaps cmake fails due to the catkin_make build system?
  2. some headers cannot be found. The file 'motion_planning_interface_tutorial.cpp' contains the following headers:
include moveit/robot_model_loader/robot_model_loader.h include moveit/planning_pipeline/planning_pipeline.h include moveit/planning_interface/planning_interface.h include moveit/kinematic_constraints/utils.h include moveit_msgs/DisplayTrajectory.h include moveit_msgs/PlanningScene.h
QT creator only finds the last two headers. In contrast to moveit_msgs, 'moveit', is not really a package and that is probably the reason why QT creator cannot find the headers. Adding the following line to Cmakelists does not solve the issue... include_directories(~/ros/workspace/moveit/src) Any idea how to point QT Creator to the headers?
Thanks!
Originally posted by Wouter on ROS Answers with karma: 130 on 2013-05-07
Comment by Fabien R on 2013-06-25:
Did you use qt_ros to create your package ?
If you can move to ubunut 14.04 or 16.04 and to ros-indigo or kinect you can use the folowing ros_qtc_pluggin to use qtcreator for ros developpement. It's quite simple to install and use
Originally posted by adrienH with karma: 38 on 2017-03-01
