I can't really understand what I'm doing wrong.. I try to get a value-object from another method.. this is my code
 #!/usr/bin/env python
class tracksendi():
def __init__(self):
    rospy.on_shutdown(self.shutdown)
    rospy.Subscriber('robotis/servo_head_pan_joint',
                     Float64, self.posisi_ax12_pan)
    rospy.Subscriber('robotis/servo_head_tilt_joint',
                     Float64, self.posisi_ax12_tilt)
    rospy.Subscriber('robotis/servo_right_elbow_joint',
                     Float64, self.posisi_ax12_elbow)
        self.operasikan_servo()
        rate.sleep()
def posisi_ax12_pan(self,pan):
    self.posisi_pan_servo = pan.data
    return
def posisi_ax12_tilt(self,tilt):
    self.posisi_tilt_servo = tilt.data
    return
def posisi_ax12_elbow(self,elbow):
    self.posisi_elbow_data = elbow.data
    return
def ambil_timestamp(self,waktu):
    self.data_time_joint_states = waktu.header.stamp
    return
def operasikan_servo(self):
# Lengan Kanan
    try:
        vektor_n_rs = self.posisi_pan_servo - self.posisi_tilt_servo
        vektor_re_rs = self.posisi_tilt_servo - self.posisi_elbow_data
    except KeyError:
        pass
if __name__ == '__main__':
    try:
    tracksendi()
except rospy.ROSInterruptException:
    pass
But, I get this error
AttributeError: tracksendi instance has no attribute 'posisi_pan_servo'
How that problem solved ???
Originally posted by Rizqa on ROS Answers with karma: 45 on 2013-04-25
Initialize all your variables in the init function. e.g. self.posisi_pan_servo = 0 etc.
Originally posted by ChickenSoup with karma: 387 on 2013-04-25
