Hello guys, I have a question about ROS architecture and how to start up a nee robotic software. I understand how ROS is organized about nodes, msgs, subscribers and so on.
After that my question is, I have a node that is related to a sensor and this sensor publish data. I have another module that will be its subscriber. My doubt is related to the usage of this data and how can I create my program, where can I insert my behavior.
Will this data be used by my custom application that is aware about the message and how to parse it ? or can I use other more complex nodes? in this case how can I customize the software?
I have not found any information about to start up a new software? I mean about the first step and high level point of view of the architecture.
Thanks a lot for your time.
Regards,
Originally posted by mbelloli on ROS Answers with karma: 1 on 2013-04-23
I think that the ROS Tutorials are the best starting point. Specifically number 11/12... but to get to those you should work the preceding ones.
If your application requires the creation of a custom message this would have been covered in tutorial 10.. but you should check the existing "standard" messages to make sure that you're not reinventing the wheel.
Originally posted by SL Remy with karma: 2022 on 2013-04-23
Post score: 5
