I am trying to integrate bluetooth in a project with MSP430 so to be able to communicate between it and my PC. Doing a search on eBay I found the following item:
HC-05 06 Transceiver Bluetooth Module Backboard Interface Base Board Serial
enter image description here
There are also a lot of other bluetooth modules that appear to be a lot more expensive and their boards are populated with IC's that this one doesn't have. So I am wondering if this is what I need or it has another use.
This module has a simple serial interface that can be hooked directly to the MCU's UART pins, and provide seamless wireless serial communication with a paired device or computer with virtual Bluetooth serial port. If this is the intention, it would be the right choice.
  • $\begingroup$ Ok that is my intention. Thank you very much! $\endgroup$
    – Adam
    Nov 25 '14 at 19:16
I suspect what you really want is a complete MCU Bluetooth module, something like the one pictured below:
(via Erich Styger "Getting Bluetooth Working with JY-MCU BT_BOARD V1.06")
When I look carefully at the above complete MCU Bluetooth module, I see 2 circuit boards soldered together:
  • the RF module, a green PCB with a gold meandering Bluetooth antenna on it and the RF integrated circuits (ICs), and
  • the interface board, a blue PCB with convenient header pins and a handful of small parts.
In the original question, I only see the blue interface board, without a RF module or even an antenna. As far as I can tell, that interface board is useless without a RF module attached to it.
My understanding is that it is impossible for Bluetooth or any other radio communication system to work without an antenna.
