Hello!
I'm using a robotic (and ROSified!) wheelchair. One of the tasks I have to do is to transform a point from /base_link
to /odom
. Unsurprisingly, I use TF :)
However, when running the code below in Python:
tfListener.canTransform("/odom", base_link_point, rospy.Time(0) )
the function returns False
quite often. I also transform from /base_link
to /map
(a longer chain) in another node and that works reliably.
I think the issue might be that tfListener doesn't have a big enough TF_CACHE_TIME, so I'd like to try and increase it. However the TF python documentation doesn't indicate how to do this.
I've also checked the source code and there's a call to override the argument in Transformer_init()
but it's not clear to me how to do so or what are the other arguments for.
Any ideas?
Originally posted by Miguel S. on ROS Answers with karma: 1114 on 2013-04-15
