In order to use RosoutPanel in C++ I include rxtools/rosout_panel.h in my class and depend on rxtools in manifest.xml. In Fuerte this works fine, but in Groovy I get a compile error because it cannot find rosout_panel.h:
fatal error: rxtools/rosout_panel.h: No such file or directory
The .h-file is present on the file system (/opt/ros/groovy/share/rxtools/src/rxtools), so why is it not found?
Originally posted by Ola Ringdahl on ROS Answers with karma: 328 on 2013-04-15
Comment by 130s on 2013-04-15:
I believe it's just your typo but rosout_panel.h not rosoutpanel.h ok?
Comment by Ola Ringdahl on 2013-04-15:
Sorry about that, I am including rosout_panel.h in the code :-)
And I assume you're using rosbuild via rosmake? If so, can you share CMakeLists.txt?
I made a very simple example that works in Fuerte but not Groovy: http://www8.cs.umu.se/~ringdahl/ros/rxtest.tar.gz
rxtools is deprecated and replaced by rqt_common_plugins in groovy
Originally posted by kalectro with karma: 1554 on 2013-04-15
Post score: 4
But since the package (and the h-file) is still there it should still work right?
Comment by kalectro on 2013-04-17:
does roscd rxtools work for you in groovy? It does not for me, so I can see why it does not find the file. Just having the .h file in your fuerte workspace will not help your groovy compilation
Comment by Ola Ringdahl on 2013-04-17:
Yes I can roscd to it and the h-files are present in the Groovy workspace as well. You have to install rxtools separately in Groovy, so that may be why why you cannot roscd to it. I used apt-get to install it.
The problem is that the .h files are not inside /opt/ros/groovy/include/rxtools but in /opt/ros/groovy/share/rxtools/src/rxtools. You could fix that by just copying the files into the right folder or use rqt which would be the nicer solution
They are in the share folder in Fuerte as well. Is this something that has changed in Groovy that they have to be in the include folder?
I haven't tested it on my own, but the phenomenon reported sounds strange.
Meanwhile, @kalectro is right. Functionality of rxtools/rosout_panel.h should be found in rqt_console -- Since its API isn't exactly the same, you have to find the equivalent.
A problem for you if you need to stick to C++ may be that it's written in python. One (boring) workaround is to have 2 pkgs, one for python to utilize rqt_console's API and the other in C++.
Originally posted by 130s with karma: 10937 on 2013-04-15
