Hi, I've been struggling with this for a few hours. I created a package depending on openni, openni_camera and openni_launch.
My problem is: on compilation, i'm getting
Linking CXX executable ../bin/listener
/opt/ros/fuerte/stacks/openni_camera/lib/libopenni_nodelet.so: error: undefined reference to 'log4cxx::Logger::getLogger(char const*)'
/opt/ros/fuerte/stacks/openni_camera/lib/libopenni_nodelet.so: error: undefined reference to 'log4cxx::Level::getError()'
/opt/ros/fuerte/stacks/openni_camera/lib/libopenni_nodelet.so: error: undefined reference to 'log4cxx::Level::getWarn()'
/opt/ros/fuerte/stacks/openni_camera/lib/libopenni_nodelet.so: error: undefined reference to 'typeinfo for log4cxx::helpers::ObjectPtrBase'
/opt/ros/fuerte/stacks/openni_camera/lib/libopenni_nodelet.so: error: undefined reference to 'log4cxx::helpers::ObjectPtrBase::~ObjectPtrBase()'
/opt/ros/fuerte/stacks/openni_camera/lib/libopenni_nodelet.so: error: undefined reference to 'log4cxx::Level::getFatal()'
I thought it was whining about the fact that I didn't link the log4cxx library on compilation. So I added this in CMakeLists.txt
rosbuild_add_library(${PROJECT_NAME} /usr/lib/liblog4cxx.so)
SET_TARGET_PROPERTIES(${PROJECT_NAME} PROPERTIES LINKER_LANGUAGE C)
but it didn't change much. Then I tried the answer from another question (which I'm not allowed to mention giving my baby karma) suggesting to use target_link_libraries() but I couldn't use it successfully.
Any ideas? NB: I'm running fuerte on ubuntu 12.04. Thanks for your help
Originally posted by tkrugg on ROS Answers with karma: 1 on 2013-04-12
Hey, I don't know if this is still useful, but I just solved a similar problem. In any case, I'll leave my solution here.
What I did was to add the following line to the begginning of my CMakeLists.txt.
link_libraries(-llog4cxx)
What this does is link every executable to the log4cxx library.
Keep in mind that link_libraries() is deprecated, so if this problem only occurs with one executable, it is preferred to use target_link_libraries(). I did not use this because the errors occurred in every executable, so link_libraries() was an easier solution.
If this does not solve your problem, don't hesitate in asking me for help, I'll try my best to help you solve the problem.
Originally posted by Throst Gunnulf with karma: 56 on 2013-08-26
