Hello. I have problem with roscore. When I try to run roscore I give this error:
Traceback (most recent call last): File "/opt/ros/groovy/lib/python2.7/dist-packages/roslaunch/init.py", line 230, in main write_pid_file(options.pid_fn, options.core, options.port) File "/opt/ros/groovy/lib/python2.7/dist-packages/roslaunch/init.py", line 106, in write_pid_file with open(pid_fn, "w") as f: IOError: [Errno 13] Permission denied: '/home/user/.ros/roscore-11311.pid'
Does someone know how I can fix it ?
Originally posted by Roboticus on ROS Answers with karma: 1 on 2013-04-09
Comment by prasanna.kumar on 2013-04-09:
If you have source /root/catkin_ws/devel/setup.bash in your .bashrc remove it, create the catkin workspace again and check.
Comment by Roboticus on 2013-04-09:
It still doesn't work. I deleted my existing workspace, source from .bashrc and create new ones still appears this error. Maybe someone else know how fix this problem. I reinstall whole ROS and still nothing. I'm begginer in ROS.
Comment by dornhege on 2013-04-10:
Something is setup wrong. You can't write to the .ros directory or that specific file. What do you get for id -a, ls -la .ros?
Hey guys, the problem could be that you ran rosdep update with sudo rights. That leads to permission errors later on.
NOTE : Run rosdep update NOT with sudo.
SOLUTION to fix this run sudo rosdep fix-permissions
and after that rosdep update.
Worked for me.
cheers
Timo
Originally posted by Timo with karma: 86 on 2015-02-12
Post score: 7
Comment by imAsim on 2015-03-17:
Perfect it does the trick for me. I was running programs from 'ROS by Example for Hydro - Volume 1'. I was not able to execute $ roslaunch rbx1_bringup fake_turtlebot.launch or $ roslaunch rbx1_bringup fake_pi_robot.launch
I would get 'IOERROR [Error13] ...'. Anyhow it is fixed now. Thanks!
Comment by luc on 2015-09-08:
the rosdep fix-permissions command worked for me!
Comment by kjerath on 2015-11-10:
Worked like a charm...
Comment by Vijay on 2016-02-16:
Awesome ,it worked.. than q @imAsim
I had a similar problem running roscore. The problem was that the hidden folder " ~/.ros" required root rights.
To solve it, I deleted the folder with:
sudo su
rm -R ~/.ros/
After that, roscore worked well and a new .ros folder was created automatically.
Originally posted by MachR with karma: 1 on 2013-04-10
If .ros required root rights, something was wrong before. Maybe some sudo call. ROS doesn't set the up as root.
Comment by MachR on 2013-04-10:
Yes, there was a mistake in the groovy installation documentation, saying to run the command with sudo. This leads to the error. The documentation is corrected now.
Comment by zurish on 2015-02-11:
It doesn't work. When I entered the two command lines "rm: cannot remove ‘/root/.ros/’: No such file or directory" showed up. What is the problem?
Comment by dornhege on 2015-02-12:
You are in the home of the root user, not in the home of the user, where you want to remove the .ros directory.
Comment by zurish on 2015-02-12:
@dornhege Thanks it's working now.
Comment by Joy16 on 2017-04-10:
Worked like charm. But could you please explain what .ros contains? I thought it only stored the logs.
