hi there,
i have ardupilot hexacopter equipped with pandaboard running ros. so i installed this mavlink-ros-pkg to control my copter via ros from here http://qgroundcontrol.org/dev/mavlink_ros_robot_operation_system_integration_tutorial. mavlink compiled fine and by running rosrun mavlink_ros mavlink_ros_serial -p /dev/ttyACM0 it publishes some data to rostopic. but now i am not sure how to use this node to control my copter?
i did find this message documentation here: https://pixhawk.ethz.ch/mavlink/ but i don`t know how to use them with ros so that my ardu gets this messages. could anyone explain, please?
i would be very happy if i could send a command like "start" through the terminal and the hexacopter starts and holds position at 3m for example. or is there any teleop-stack ready? this would be very great.
thanks!
Originally posted by RodBelaFarin on ROS Answers with karma: 235 on 2013-04-09
Comment by Giona Grancheli on 2013-05-10:
I have the same problem :(
Comment by lanyusea on 2014-05-18:
Hi, did you find any document or wiki at last? I can find one nowhere(
Comment by RodBelaFarin on 2014-05-19:
hi there, for the start i recommend to work with "roscopter". this one woks, but there is still a lot of work. good luck!
