Is it possible to visualize a topic of type sensor_msgs/LaserScan using rviz? Currently it complains about not having any frame (which is true, I just have the scan data)... Is there a better way?
Thanks in advance.
Originally posted by tommyo on ROS Answers with karma: 27 on 2013-04-03
Which laserdriver are you using? Normally every sensor message has a frame attached. (You can find out this frame by using rostopic echo /scan -n 1 --noarr)
If no transforms are published, rviz will not show that frame as a possibility in the Fixed Frame dropdown-menu. But if you just type in the frame-name by hand, rviz should be able to visualize your laserscan.
Originally posted by Ben_S with karma: 2510 on 2013-04-03
Comment by tommyo on 2013-04-03:
I'm not sure what you're getting at, but i found this in the output: frame_id: '' The publishing node a bridge between another system and ROS so if something needs to be added I'm open to that. Thanks.
Comment by Ben_S on 2013-04-03:
Have you written this bridging node yourself? The header of the message should contain a valid frame name/id (for example laser, try setting laserscan_msg->header.frame_id) and a timestamp.
Sorry, I am kind of lost when it comes to visualization and the like. What is the simplest thing that could pass as a valid frame? At this point the scanner is just sitting on the desk with no odometry or maps available. Is it possible visualize the environment around a fixed scanner?
Like i mentioned, laser would be a valid frame id. You can read this about the naming conventions for frames: http://www.ros.org/wiki/geometry/CoordinateFrameConventions#Naming
Now I get it, and it works fine. Thank you!
