I'm trying to implement a nearest-neighbor structure for use in an RRT motion planner. In order to do better than a linear brute-force nearest-neighbor search, I'd like to implement something like a kd-tree. However, it seems like the classical implementation of the kd-tree assumes that each dimension of the space can be split into "left" and "right". This notion doesn't seem to apply to non-Euclidean spaces like SO(2), for instance.
I'm working with a serial manipulator arm with fully rotational links, meaning that each dimension of the robot's configuration space is SO(2), and therefore non-Euclidean. Can the kd-tree algorithm be modified to handle these kinds of subspaces? If not, is there another nearest-neighbor structure that can handle these non-Euclidean subspaces while still being easy to update and query? I also took a look at FLANN, but it wasn't clear to me from their documentation whether they can handle non-Euclidean subspaces.
