I want to run a simple PCL program, but it gave error like "Unable to start program c:\GrabPCD\build_pcl\x64\Debug\All_build The system can`t find the file specified."
I am using Windows7 MSVC2010.
#include <iostream>
#include <pcl/io/pcd_io.h>
#include <pcl/point_types.h>
int
  main (int argc, char** argv)
  pcl::PointCloud<pcl::PointXYZ> cloud;
  // Fill in the cloud data
  cloud.width    = 5;
  cloud.height   = 1;
  cloud.is_dense = false;
  cloud.points.resize (cloud.width * cloud.height);
  for (size_t i = 0; i < cloud.points.size (); ++i)
    cloud.points[i].x = 1024 * rand () / (RAND_MAX + 1.0f);
    cloud.points[i].y = 1024 * rand () / (RAND_MAX + 1.0f);
    cloud.points[i].z = 1024 * rand () / (RAND_MAX + 1.0f);
  pcl::io::savePCDFileASCII ("test_pcd.pcd", cloud);
  std::cerr << "Saved " << cloud.points.size () << " data points to test_pcd.pcd." << std::endl;
    std::cerr << "    " << cloud.points[i].x << " " << cloud.points[i].y << " " << cloud.points[i].z << std::endl;
  return (0);
Originally posted by Nihad on ROS Answers with karma: 22 on 2013-03-30
You should set the startup project that will be launched when you click F5 in Visual Studio. By default, the startup project is ALL_BUILD. right click on the project you want in the solution explorer, and choose "set as startup project".
Originally posted by hiranya with karma: 104 on 2013-03-31
Comment by Nihad on 2013-03-31:
Thank you. It works fine.
