Hi guys !
I am getting this error when i try to compile the bumblebee2 package of Columbia University :
[ rosmake ] All 32 linesumblebee2: 4.2 sec ] [ 1 Active 45/46 Complete ] {------------------------------------------------------------------------------- mkdir -p bin cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=/opt/ros/groovy/share/ros/core/rosbuild/rostoolchain.cmake .. [rosbuild] Building package bumblebee2 [rosbuild] Cached build flags older than manifests; calling rospack to get flags Failed to invoke /opt/ros/groovy/bin/rospack cflags-only-I;--deps-only bumblebee2 Package camera_info_manager was not found in the pkg-config search path. Perhaps you should add the directory containing `camera_info_manager.pc' to the PKG_CONFIG_PATH environment variable No package 'camera_info_manager' found Traceback (most recent call last): File "/usr/lib/pymodules/python2.7/rosdep2/rospack.py", line 45, in call_pkg_config value = subprocess.check_output(['pkg-config', option, pkg_name]) File "/usr/lib/python2.7/subprocess.py", line 544, in check_output raise CalledProcessError(retcode, cmd, output=output) subprocess.CalledProcessError: Command '['pkg-config', '--cflags-only-I', 'camera_info_manager']' returned non-zero exit status 1 [rospack] Error: could not call python function 'rosdep2.rospack.call_pkg_config'
CMake Error at /opt/ros/groovy/share/ros/core/rosbuild/public.cmake:129 (message):
Failed to invoke rospack to get compile flags for package 'bumblebee2'.
Look above for errors from rospack itself.  Aborting.  Please fix the
broken dependency!
Call Stack (most recent call first): /opt/ros/groovy/share/ros/core/rosbuild/public.cmake:227 (rosbuild_invoke_rospack) CMakeLists.txt:12 (rosbuild_init)
[ rosmake ] Output from build of package bumblebee2 written to: [ rosmake ] /home/anis/.ros/rosmake/rosmake_output-20130329-160036/bumblebee2/build_output.log
[rosmake-1] Finished <<< bumblebee2 [FAIL] [ 4.22 seconds ]
[ rosmake ] Halting due to failure in package bumblebee2. [ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 46 packages with 1 failures.
[ rosmake ] Summary output to directory
I already installed the camera_info_manager package and it compiles without any failure. This is what i get with the roscd pkg :
anis@anis-Precision-M4500:~/rgbdslam_workspace$ roscd camera_info_manager
anis@anis-Precision-M4500:~/rgbdslam_workspace/sandbox/image_common-groovy-devel/camera_info_manager$
I looked for the "camera_info_manager.pc" file in all my system and i don't find it.
Originally posted by INSA on ROS Answers with karma: 112 on 2013-03-29
Hi guys i fixed the problem by replacing the camera_info_manager by an other one that i found on the version 1.6 of the image_common stack image_common-1.6/camera_info_manager
Originally posted by INSA with karma: 112 on 2013-03-29
