Hi,
I'm having a problem with the openni registration on a kinect. As many people around here when i enable the depth_registration option i only receive NaN's. This is on a fresh install of booth ubuntu 12.04 and ros groovy from yesterday. I allready tried to follow this "tutorial" here and here because it's the same problem, but i still can't get the thing to work, and running the OpenNi samples every thing is great.
This is a problem that exists for a long time and no solution yet... It's very annoying because i need it for my thesis
What can i try to solve this?
Thanks
Originally posted by jcc on ROS Answers with karma: 200 on 2013-03-28
Comment by ee.cornwell on 2013-03-28:
I am having the same problem on my laptop: HP Mini 210 w/ Intel Atom, Ubuntu Precise-Fuerte. Depth registration set to true in openni.launch causes all NAN values. I am betting this is system dependent because my other laptop with an AMD processor and graphics card works well with openni depth registration (same software).
Comment by jcc on 2013-03-28:
I also think it is hardware dependent. working on my room there is another studend with a different pc and everything works fine (just by instaling openni-camera and launch). For me the strange thing is that the OpenNi binaries works flawless on every pc, but the ROS (and PCL?) library doesn't
Comment by jcc on 2013-04-15:
If you have this problem please say it on the github page. here is my issue ticket: https://github.com/ros-drivers/openni_camera/issues/13
They didn't seem to find that important (it seams they didn't even read thing right), maybe if more users put the same issue...
Comment by Lucile on 2013-05-23:
Hi ! I am struggling with the same problem. Did you find a solution ?
Comment by jcc on 2013-05-23:
My "solution" was to switch to a 64bits ubuntu.
Ok. Thank you. My Turtlebot was delivered with a 32 bits computer, so I'll have to deal with it.
This is a bug in Libopenni-dev. It does not work proper with 32 bit OS. You may work with an older version or install a 64 bit OS. Regards ,O3
Originally posted by o3p7s5 with karma: 86 on 2013-12-19
