I'm running into this problem while trying to build tf2_ros on OSX:
==> make -j4 -l4 in '/Users/Yeison/ros_catkin_ws/build_isolated/tf2_ros'
Linking CXX shared library /Users/Yeison/ros_catkin_ws/devel_isolated/tf2_ros/lib/libtf2_ros.dylib
Undefined symbols for architecture x86_64:
Full output: https://gist.github.com/yeison/5244835
I think the following patch is meant to address the issue:
https://github.com/ros/geometry-experimental/pull/6
I'll have to try and pull those changes in locally to test.
Originally posted by Yeison Rodriguez on ROS Answers with karma: 103 on 2013-03-26
That seems to have worked!
Originally posted by Yeison Rodriguez with karma: 103 on 2013-03-26
Comment by Markus Achtelik on 2013-03-26:
I just ran into this as well and the fix worked fine! Thx a lot!
Comment by Yeison Rodriguez on 2013-03-29:
I'm glad that helped. Thanks to @WilliamWoodall for that patch.
