This is a pretty simple question I imagine but I want to make sure that I'm understanding things correctly BEFORE I get too involved.
I want to use the OpenNi drivers for a PrimeSense RGBD sensor, I'll actually use any drivers, but OpenNi seems to be the most supported.
The ROS package for all things OpenNi says that it is deprecated in Fuerte. It says that you should compile directly against the system dependency instead.
This is the part I want to make sure I understand correctly. I should download and install the driver/library directly from http://www.openni.org/ and then link to those instead of a ros package?
Also just out of curiosity, does anyone know why this package has become deprecated?
Originally posted by skiesel on ROS Answers with karma: 549 on 2013-03-22
I'm not sure which page you are looking at, but:
Are the drivers and easy launch files for using Kinect or Asus/Primesense sensor. I'm not sure it will work with one of the earlier Primesense SDK5 sensors as there were so few of them around I doubt anyone is testing against them.
Note: I've quickly fixed the docs so that the fuerte docs show for groovy as they should be mostly the same.
Originally posted by fergs with karma: 13902 on 2013-03-22
Comment by skiesel on 2013-03-23:
Thanks for the information. I was looking at the fuerte version of this page: http://www.ros.org/wiki/openni
