Does anyone have a decent tutorial for using rosjava and a PR2? Even a simple tutorial would be greatly beneficial.
Anything with the PR2, actionlib, rosjava groovy would be a great help. I can't find anything.
Thanks, James
Originally posted by jforkey on ROS Answers with karma: 82 on 2013-03-19
As you've covered all the ROSJAVA documentation, you'll find that ROSJava_core development separate from the roscpp development cycles such as Groovy and Fuerte. The integration between a PR2 (or any system) and ROSJAVA is through the message interface. On thing that may restrict you is the lack of a action interface in ROSJAVA. Your solution in that case is to write a node implementing the interface in another language as a proxy.
Other than that it would be a matter of determining the interface you are after and implementing it using the publishers, subscribers,servers and clients in rosjava_core. All the message types are available in rosjava_core.
EDIT
I dont have a tutorial, but I used rosjava to publish GetMotionPlan messages to the ompl_planning node. The key to using these complex message types is creating a variable from the interface using node.getTopicMessageFactory().newFromType(TYPE) as in the example:
trajectory_msgs.JointTrajectoryPoint point1= node.getTopicMessageFactory().newFromType(JointTrajectoryPoint._TYPE);
This allows complex messages, particularly those that contain Java List<> types to be filled and then placed in the message field using one of the message interface's set commands.
Originally posted by PeterMilani with karma: 1493 on 2013-03-21
Comment by jforkey on 2013-03-21:
Can you point to a tutorial that does this for any single interface?
Comment by PeterMilani on 2013-03-22:
see edit above
There are general support guidelines.
Each important component has its wiki page with everything appertaining:
  • rosjava, docs etc. linked there.
  • PR2, tutorials etc. linked there.
  • actionlib, tutorials linked there.
To get an idea how to glue components read the introduction.
To find code browse the ros.
Originally posted by felix k with karma: 1650 on 2013-03-21
A) The rosjava link simply references another external link, which I have read entirely multiple times.
B) The PR2 link contains links for other versions of ROS, not groovy, or anything about rosjava. C) The actionlib link is for ROS (C++), not rosjava.
Comment by felix k on 2013-03-21:
So I'm glad your question wasn't as blunt as it seems to me due to those aspects missing. :)
