I want to run the rgbd slam package provided on open slam website with ROS groovy. The readme file with the package has instructions for diamondback. I have downloaded the package along with the hogman_minimal library. I have also edited the manifest.xml file adding for openni dependency. But now when I run rosdep install rgbdsalm_freiburg, I get error:
ERROR: Rosdep cannot find all required resources to answer your query
Missing resource rgbdsalm_freiburg
ROS path [0]=/opt/ros/groovy/share/ros
ROS path [1]=/opt/ros/groovy/share
ROS path [2]=/opt/ros/groovy/stacks
I am sure my RGBD slam package is in the $ROS_PACKAGE_PATH variable because when I do roscd rgbdslam, I am able to change my directory to rgbdslam folder.
How can I make it work?
Originally posted by Robetraks on ROS Answers with karma: 11 on 2013-03-14
you spelled it wrong. It should be rgbdslam_freiburg :)
Originally posted by kalectro with karma: 1554 on 2013-03-14
