I am trying to use rosserial on Raspbian using ROS Groovy. I am trying to run rosrun rosserial_python serial_node.py /dev/ttyACM0 but I get this error [ERROR] [WallTime: 1363226987.379253] Tried to publish before configured, topic id 125. I compile the code on an Ubuntu 12.04 laptop and can get it to run on the Ubuntu machine but as soon as I plug it into the Raspberry Pi, I get that error. Any ideas?
Thanks in advance.
Originally posted by tonybaltovski on ROS Answers with karma: 2549 on 2013-03-13
Post score: 4
I upgrade the rosserial on the Raspi to the latest one and it worked locally on the Raspi but the Master could not echo the topic. Will the sudo apt-get ros-groovy-rosserial be updated to the latest version?
Originally posted by tonybaltovski with karma: 2549 on 2013-03-19
Comment by fergs on 2013-03-19:
Debians only sync to public every so often. The updated rosserial is currently in shadow-fixed, so it will be in the next public sync, but I don't know when that will occur.
Comment by tonybaltovski on 2013-03-19:
Is there a major difference between the current stable source version and one available from public sync?
Comment by fergs on 2013-03-26:
Quite a bit. Originally, 0.2.0 got released by the groovy migration team as 0.3.0 wouldn't build. Recently we've released 0.4.x (currently 0.4.4 I believe). The 0.4.0 series has a number of fixes and improvements. It should be in public debians as of this last sync.
Comment by tonybaltovski on 2013-03-26:
I installed the latest from source and it works fine. Thanks. The one from the public debians gave me problems. Any updates on rosserial_xbee?
rosserial_xbee has not been maintained for quite some time, as such it has been moved into the rosserial_experimental stack.
Is there a reason why it is not maintained? Will the kforge version work on groovy using rosmake?
Nobody has stepped forward to maintain it. It may work via rosmake, not entirely sure. We did move it to https://github.com/ros-drivers/rosserial-experimental so that it would not be lost if Kforge eventually dies.
Is the package just lacking catkinization? Can you recommend a solution for wireless communicating to an Arduino?
Certainly it is lacking catkinization, beyond that I have no idea what else may or may not be working inside, especially given the recent refactoring of rosserial to handle numerous changes/deprecations in roslib.
Comment by HenryW on 2013-03-31:
Hi I am currently getting this error message when running on an Arduino Mega via a PC running Ubuntu 12.04.
I have install rosserial via "sudo apt-get ros-groovy-rosserial" but still get this error. Not sure how to update the version or fix this off your comments here :-( what did you do to fix?
Comment by tonybaltovski on 2013-03-31:
Install from source to fix it. Here is the link https://github.com/ros-drivers/rosserial
ok cool, following the install from source guide on the rosserial page. When running "catkin_make install" I get an error saying "Invoking "make" failed"
Apply this fix: https://github.com/edsfocci/rosserial/commit/56857cb97c010e353d304832acb1ceec22c0d933
Comment by HenryW on 2013-04-01:
That worked perfectly, thank you!
Comment by tonybaltovski on 2013-04-01:
Glad to hear.
