I would like to use a safety controller with my turtlebot 2, so that I can take into account bumper's state when navigating.
Is there a safety controller that has been created for the turtlebot 2 or should I use the same one than for the kobuki base ? Is there a nodelet manager started in turtlebot_bringup/minimal.launch ?
UPDATE :
When I tried to do this tutorial : http://www.ros.org/wiki/kobuki/Tutorials/Write%20your%20own%20controller%20for%20Kobuki using only the kobuki_node/minimal.launch it works. But I would like to use turtlebot_bringup/minimal.launch but no nodelet manager seems to be started...
Can someone help me ?
Originally posted by CarolineQ on ROS Answers with karma: 395 on 2013-03-11
Comment by Daniel Stonier on 2013-03-11:
Should work - kobuki, turtlebot-kobuki and turtlebot-create all start nodelet managers with the name mobile_base_nodelet_manager. You can find the turtlebot nodelet manager in https://github.com/turtlebot/turtlebot/blob/master/turtlebot_bringup/launch/includes/kobuki/_mobile_base.launch
What version of the kobuki and turtlebot stacks do you have?
Hi CarolineQ,
the safety controller for Kobuki also works with Turtlebot 2. However, you have to adapt the launch file a bit. This modified version of kobuki_keyop/safe_keyop.launch file should allow you to drive your turtlebot around with the safety controller watching over it.
  Keyop configuration for working with the default Turtlebot launcher (minimal.launch).
<launch>
  <node pkg="nodelet" type="nodelet" name="kobuki_safety_controller" args="load kobuki_safety_controller/SafetyControllerNodelet mobile_base_nodelet_manager">
    <remap from="kobuki_safety_controller/cmd_vel" to="cmd_vel_mux/input/safety_controller"/>
    <remap from="kobuki_safety_controller/events/bumper" to="mobile_base/events/bumper"/>
    <remap from="kobuki_safety_controller/events/cliff" to="mobile_base/events/cliff"/>
    <remap from="kobuki_safety_controller/events/wheel_drop" to="mobile_base/events/wheel_drop"/>
  </node>
  <node pkg="nodelet" type="nodelet" name="keyop_vel_smoother" args="load yocs_velocity_smoother/VelocitySmootherNodelet mobile_base
_nodelet_manager">
    <rosparam file="$(find kobuki_keyop)/param/keyop_smoother.yaml" command="load"/>
    <remap from="keyop_vel_smoother/odometry" to="odom"/>
    <remap from="keyop_vel_smoother/smooth_cmd_vel" to="cmd_vel_mux/input/teleop"/>
  </node>
  <node pkg="kobuki_keyop" type="keyop" name="keyop" output="screen">
    <remap from="keyop/motor_power" to="mobile_base/commands/motor_power"/>
    <remap from="keyop/cmd_vel" to="keyop_vel_smoother/raw_cmd_vel"/>
    <param name="linear_vel_step"  value="0.05" type="double"/>
    <param name="linear_vel_max"   value="1.5"  type="double"/>
    <param name="angular_vel_step" value="0.33" type="double"/>
    <param name="angular_vel_max"  value="6.6"  type="double"/>
    <param name="wait_for_connection_" value="true" type="bool"/>
  </node>
</launch>
The major difference between kobuki_node/minimal.launch and turtlebot_bringup/minimal.launch is, that the latter already starts the velocity muxer. That plus few adjustments to the topic remappings is all that is needed.
I suggest, you start with this launch file and adapt it to your needs.
Good luck!
Originally posted by bit-pirate with karma: 2062 on 2013-03-11
Comment by CarolineQ on 2013-03-11:
Yes I think this will work ! Thanks for the answer !
