I'm trying to get ccny_rgbd working on a turtlebot. It seems to be kind of working but I think it's still not quite working as it should.
On the turtlebot I launch:
roslaunch ccny_openni_launch openni.launch publish_cloud:=true
I get a complaint in the terminal about a missing camera calibration file but it still seems to run anyway.
Then on the workstation I launch:
roslaunch ccny_rgbd vo+mapping.launch
I run the corresponding rViz config file. At this point I did get a rgbd image in rViz but it takes a very long time, several minutes. I left it running for a while and it did update the rgbd image but the update rate was very slow. Again several minutes per image. Other times it doesn't give me the rgbd image at all after waiting up to 10min. I'm sure this isn't normal but I'm not really sure where to ever start at trying to fix it. Maybe my computer is just too slow for this?
I also tried to record a bag file to try and process the data later but ran into a problem with the TF data being old. Not sure what's going on there either. It seems to run fine when I'm not trying to record the bag file.
Originally posted by jd on ROS Answers with karma: 62 on 2013-03-10
Comment by Ivan Dryanovski on 2013-03-10:
Can you post information about your setup? What's your processor? Is anything running over a wifi network?
Comment by jd on 2013-03-10:
The turtlebot has a dual intel atom 1.86Ghz processor. The workstation I'm worried about. It's an acer laptop with an AMD triple core at 2.1Ghz. I've tried it on two networks both seem to give the same result. I do have an unused router that I could use to set up a network just for turtlebot.
