Hello to all,
I created a Robot-Config via MoveIt! Setup Assistant. The Robot is a simple 6 Dof Robot.
When I start it with the Rviz Moveit Plugin the interactive markers are not displayed. (After I click on "Interact"). I suspect the End-Effector is not correctly set by me.
RVIZ:
image description
Screenshots of the MoveIt Setup Assistant:
1. image description
2. image description
I set for both plannings groups the "KDLKinematicsPlugin" as Solver on default values. I followed this tutorial for the pr2-robot.
My .launch-file:
<launch>
<include file="$(find tx60l_final3)/launch/upload_tx60l.launch"/>
<node pkg="tf" type="static_transform_publisher" name="odom_broadcaster" args="0 0 0 0 0 0 odom_combined base_footprint 100" />
<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher">
 <param name="/use_gui" value="false"/>
</node>
<node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher" respawn="true" output="screen"/>
  <include file="$(find tx60l_final3)/launch/move_group.launch">
    <arg name="allow_trajectory_execution" value="false"/>
  </include>
<include file="$(find tx60l_final3)/launch/moveit_rviz.launch"/>
</launch>
Edit (no gazebo-part in urdf): See here the Terminal-Output.
Info: Removing and adding "MotionPlanning" inside Rviz didn't help.
Edit (working Links): Here you can download my robot-description. Here you can download my urdf-folder.
Update: If I set the "fixed_frame" to a link of the robot itself, interactive markers for joint a4 show up. (See picture below) But I need interactive markers in joint5. If I let "fixed_frame" set on "base_footprint" or "odom_combined" (as it should be, I think) and "plan and execute" for a random query MoveIt! crashes (output)
image description
Update: Now the interactive markers work correctly. Many Thanks to all supporters.
viovio
Originally posted by viovio on ROS Answers with karma: 117 on 2013-03-09
Post score: 4
Comment by Jeremy Zoss on 2013-03-14:
Please mark an answer as correct, so the question is flagged as "answered". Glad it's working for you! Consider looking into http://ros.org/wiki/Industrial, which has several tutorials and templates for controlling your industrial robot through ROS. We'd love to add support for Staubli to ROS-I !
Comment by ROSkinect on 2015-03-03:
did you tried to connect that to real robot or the simulator ?
3 Answers 3
To me, it looks like the issue is that your joint_state_publisher is crashing due to a malformed robot URDF. See the following snippet from your error log:
xml.parsers.expat.ExpatError: unbound prefix: line 3, column 4
[joint_state_publisher-3] process has died
I was able to reproduce the error using the tx60l.urdf supplied in your links. The issue here is with the <gazebo> section in your URDF. The joint_state_publisher uses a python minidom XML parser, which is more picky about XML syntax than the TinyXML C++ parser used in much of the rest of ROS (including the check_urdf test you ran earlier). Even though the TinyXML parser can handle your URDF, the minidom parser requires a little bit more help...
To fix the error, you have two options:
  1. remove the <gazebo> section from your URDF
  2. or update the URDF to a "more correct" format:
  3. move the <gazebo> section inside the <robot> section
  4. add xmlns qualifiers to the robot tag as shown:
<robot name="TX60L">
       xmlns:controller="http://playerstage.sourceforge.net/gazebo/xmlschema/#controller"
       xmlns:interface="http://playerstage.sourceforge.net/gazebo/xmlschema/#interface">
  <gazebo>
  </gazebo>
  <link name="base_link">
</robot>
Using these changes, I was able to get the joint_state_publisher to run without errors. I expect this will also fix the issue you were having with missing interactive markers.
Originally posted by Jeremy Zoss with karma: 4976 on 2013-03-14
Comment by viovio on 2013-03-14:
Thx for your answer. I updated the links, so it must work now. My urdf file seems to be fine according to check_urdf.
In the meantime I also noticed this. I removed it and the joint_state_publisher starts correctly. But this doesn't solve the problem. But I noticed something interesting: When setting the fixed_frame from odom_combined to a link of the robot itself, interactive markers appear for the a4-link!
I think you are seeing the correct behavior. What are you expecting to see? For a fixed robot, you shouldn't need to define odom_combined. It is appropriate to set the fixed_frame in rviz to base_link of your robot.
Similarly, at4 is the last link in your robot_arm group. That's where the markers should be shown. If you prefer to include the at5 link, then you need to add it to your robot_arm group. This may require you to use a dummy (fixed) joint for the EE group, if you don't have a true gripper.
Thx. I followed your comment and the interactive markers are now on their right spot.
Have you tried disabling and then re-enabling the MoveIt plugin? I've noticed in the past that if RVIZ starts before MoveIt is really up and running, the markers don't work.
Originally posted by fergs with karma: 13902 on 2013-03-09
Comment by viovio on 2013-03-10:
Not yet, how can I do that?
Comment by fergs on 2013-03-10:
On each plugin there is a checkbox next to it to enable/disable it.
Unfortunately it does not work. I guess you mean the checkbox next to MotionPlanning in Panel "Displays".
Comment by severin on 2013-03-13:
I confirm that disabling/enabling the MotionPlanning panel does fix the issue for me.
If anyone else comes across this issue, you can get more debug info with the following steps:
  1. In the Displays panel of RViz, click Add > By topic > select InteractiveMarkers under /rviz_moveit_motion_planning_display
  2. In my case I see the error "Error getting time of latest transform between /world and world: (error code: 1)" for this interactive marker in the Displays panel.
This helped me debug that my issue is related to the robot being in a namespace. (A quick fix in this case is to manually publish the transform with "rosrun tf static_transform_publisher 0 0 0 0 0 0 1 /world /{robot_namespace}/world 10")
Comment by oldham on 2017-07-26:
Your error is similar to mine, but when I try your fix it doesn't work for me. Could it be a problem simply with having slashes?
Comment by dhood on 2017-07-26:
what's the error that you see? the frames with/without a slash in the error message that I mentioned have significantly different meaning: '/world' is a global frame and 'world' is a local frame. Probably whatever was publishing it as a local frame (I forget what) should have been doing it as global
Ah okay! I was revising a different deprecated MoveIt! tutorial but I found the issue once the global/local difference was made clear. Thanks for your help.
glad to hear that helped
