Hi, I've copied the code from the tutorial "publisher and subscriber", and tried to modify it to read serial data from an an arduino and publish it. Here is the code for my publisher:
#!/usr/bin/env python
import roslib; roslib.load_manifest('beginner_tutorials')
import rospy
import serial
def talker():
    ser = serial.Serial('/dev/ttyACM0', 9600)
    pub = rospy.Publisher('chatter', String)
    rospy.init_node('talker')
        ser.readline()
        rospy.loginfo(ser)
        pub.publish(String(ser))
        rospy.sleep(1.0)
if __name__ == '__main__':
    try:
        talker()
    except rospy.ROSInterruptException:
        pass
The code for my listener is unchanged from the tutorial. when I rosrun them both the publisher stop with the following error message:
File "/home/pi/fuerte_workspace/sandbox/serial_message/scripts/talker.py", line 22, in
    talker()
  File "/home/pi/fuerte_workspace/sandbox/serial_message/scripts/talker.py", line 16, in talker
  File "/opt/ros/fuerte/lib/python2.7/dist-packages/ros_comm-1.8.12-py2.7.egg/rospy/topics.py", line 796, in publish
    raise ROSSerializationException(str(e))
rospy.exceptions.ROSSerializationException: field data must be of type str
What is it I'm doing wrong and how and I resolve this issue? (I'm aware I can ser up the Arduino to publish directly though I'd like to avoid it as that would require a large modification to my Arduino code.)
Amend: After adding the following code:
sensor = ser.readline()
rospy.loginfo(sensor)
pub.publish(String(sensor))
When I run them both I get the following error from the listener.
[ERROR] [WallTime: 1362846465.102142] bad callback:
  File "/opt/ros/fuerte/lib/python2.7/dist-packages/ros_comm-1.8.12-py2.7.egg/rospy/topics.py", line 678, in _invoke_callback
    cb(msg)
  File "/home/pi/fuerte_workspace/sandbox/serial_message/scripts/listener.py", line 8, in callback
    rospy.loginfo(rospy.get_name() % data.data)
TypeError: not all arguments converted during string formatting
How do I fix this?
Originally posted by ianphil397 on ROS Answers with karma: 11 on 2013-03-09
Comment by ianphil397 on 2013-03-09:
Okay so I need something like
data = ser.readline()
then
pub.publish(String(data))
Comment by dornhege on 2013-03-09:
Your listener printout in loginfo is wrong. This is unrelated to this question. Please open a new one.
Comment by uzair on 2014-04-30:
DId your code work?
You are publishing the Serial object instead of the line that you read from it (which you store nowhere).
Originally posted by dornhege with karma: 31395 on 2013-03-09
