The paper Controlling of Quadrotor UAV Using a Fuzzy System for Tuning the PID Gains in Hovering Mode by E. Abbasi, M. J. Mahjoob explains how to tune PID gains with fuzzy logic. You can find many papers about singleton tuning but this paper shows totally fuzzy control
- find PID gains with ziegler-nichols (or another technique)
- Create a fuzzy PID gain changer which has inputs error (e) and change in error(de)
Define fuzzification graphs for inputs and outputs. Define limits (also you can change the shape) like
name [min,peak,max]
very small [-1,-1,-0.6], small [-1,-0.6,0], medium [-0.6,0,0.6], big [0,0.6,1], very big [0.6,1,1]
create rules like
if **e** and/or **de** *fuzzyname* (small,big etc.) than KI is fuzzyname (small,big etc.)
Defuzzyfy the result.
You can use tools like matlab fuzzy toolbox or python skfuzzy
The tipping problem can be used as Fuzzy-PID just change qualtiy as e and service as de and lastly you can change tip output as KP/ KI/ KD
(there is example about tipping problem: python scikit fuzzy - Fuzzy Control Systems: The Tipping Problem)
Note 1: Error ranges should be well defined so you must log the error and change in error. The limits must be in max and min values of these values
Note 2: The output value range is good between -1 and 1.
An example code for Fuzzy-PID in python is here:
# -*- coding: utf-8 -*-
@author: acs
import skfuzzy as fuzz
from skfuzzy import control as ctrl
import acspid
import numpy as np
from matplotlib import pyplot as plt
plt.ion()
fig=plt.figure()
ferr = ctrl.Antecedent(np.arange(-150, 150, 1), 'ferr')
fder = ctrl.Antecedent(np.arange(-150, 150, 1), 'fder')
fout = ctrl.Consequent(np.arange(-1, 1, 0.01), 'fout')
ferr.automf(5)
fder.automf(5)
fout.automf(5)
fout['poor'] = fuzz.trimf(fout.universe, [-1, -1, -0.5])
fout['mediocre'] = fuzz.trimf(fout.universe, [-1, -0.5, 0])
fout['average'] = fuzz.trimf(fout.universe, [-0.1, 0, 0.1])
fout['decent'] = fuzz.trimf(fout.universe, [0, 0.5, 2])
fout['good'] = fuzz.trimf(fout.universe, [0.5, 1, 1])
fout.view()
ferr.view()
fder.view()
plt.show()
plt.pause(0.0001)
#'poor'; 'mediocre'; 'average'; 'decent', or 'good'
rules=[]
rules.append(ctrl.Rule(ferr['average'] | fder['average'] , fout['average']))
rules.append(ctrl.Rule(ferr['decent'] | fder['decent'] , fout['decent']))
rules.append(ctrl.Rule(ferr['good'] | fder['good'] , fout['good']))
rules.append(ctrl.Rule(ferr['mediocre'] | fder['mediocre'] , fout['mediocre']))
rules.append(ctrl.Rule(ferr['poor'] | fder['poor'] , fout['poor']))
fctrl = ctrl.ControlSystem(rules)
fpid = ctrl.ControlSystemSimulation(fctrl)
pid=acspid.pidcont(1.2,0.02,0.01,5,-5)
pid2=acspid.pidcont(1.2,0.02,0.01,5,-5)
d=np.zeros(10)
for i in range(10):
d=np.append(d,np.ones(10)*np.random.uniform(-100,100,1))
print len(d)
m=[]
m.append(0.0)
m2=[]
m2.append(0.0)
e=[]
de=[]
e2=[]
de2=[]
kp=pid.kp
kd=pid.kd
ki=pid.ki
for i in range(len(d)):
pid.setDesired(d[i])
print "e:",pid.error ,"\t de:", pid.ed
fpid.input['ferr'] = pid.error
fpid.input['fder'] = pid.ed
fpid.compute()
newpid=np.abs(fpid.output['fout'])
print "PID:", newpid*pid.kp,"\t",newpid*pid.ki,"\t",newpid*pid.kd
pid.setGains(newpid*kp,newpid*ki,newpid*kd)
newm=pid.update(m[-1])
newm=m[-1]+newm
print i,m[-1],newm
m.append(newm)
e.append(pid.error)
de.append(pid.ed)
pid2.setDesired(d[i])
newm2=pid2.update(m2[-1])
newm2=m2[-1]+newm2
m2.append(newm2)
e2.append(pid2.error)
de2.append(pid2.ed)
ax1 =plt.subplot(2,1,1)
ax1.set_xlim([0, len(d)])
ax1.set_ylim([-200, 200])
plt.grid()
plt.plot(range(len(m)),m,linewidth=5.0)
plt.plot(range(len(m2)),m2,linewidth=2.0)
plt.plot(range(len(d)),d,'g--')
plt.title('Status')
ax2=plt.subplot(2,1,2)
ax2.set_xlim([0, 50])
ax2.set_ylim([-100, 100])
plt.plot(range(len(e)),e,'r-',range(len(de)),de,'g-')
plt.grid()
plt.title('e and ed')
#plt.draw()
plt.show()
plt.pause(0.0001)
Fuzzy input membership functions:
Fuzzy output Membership function:
Status: In the status plot dashed line is target value, red line is PID and green line is Fuzzy-PID
Here the acspid class
class pidcont():
def __init__(self,P,I,D,pmax,pmin):
self.kp=P
self.kd=D
self.ki=I
self.pidmax=pmax
self.pidmin=pmin
self.desired=0.0
self.error=0.0
self.elast=0.0
self.esum=0.0
self.eder=0.0
def update(self,current):
self.error=self.desired-current
self.eder=self.error-self.elast
self.elast=self.error
self.esum=self.esum+self.error
if self.esum>self.pidmax:
self.esum=self.pidmax
elif self.esum<self.pidmin:
self.esum=self.pidmin
self.P=self.kp*self.error
self.D=self.kd*self.eder
self.I=self.ki*self.esum
pid=self.P+self.I+self.D
return pid
def setDesired(self,d):
self.desired=d
def setGains(self,P,I,D):
self.kp=P
self.kd=D
self.ki=I
def setLimits(self,pmax,pmin):
self.pidmax=pmax
self.pidmin=pmin
