I have been using OpenCV without issue for months, but today when I catkin_make my workspace I now get the error:
-- +++ processing catkin package: 'clam_vision' -- ==> add_subdirectory(clam_vision) CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:71 (find_package): Could not find a configuration file for package vision_opencv.
Set vision_opencv_DIR to the directory containing a CMake configuration file for vision_opencv. The file will have one of the following names:
vision_opencvConfig.cmake
vision_opencv-config.cmake
clam_vision/CMakeLists.txt:7 (find_package)
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:71 (find_package): Could not find a configuration file for package opencv2.
Set opencv2_DIR to the directory containing a CMake configuration file for opencv2. The file will have one of the following names:
opencv2Config.cmake
opencv2-config.cmake
I have tried reinstalling ros-groovy-vision-opencv and ros-groovy-opencv2. Searching my computer I found lots of files named opencv.cmake in different locations.
I have made no changes except updating ROS, and everything seems to be installed and working correctly, so I do not understand what the issue is.
Originally posted by Dave Coleman on ROS Answers with karma: 1396 on 2013-02-28
Comment by zweistein on 2013-03-04:
I'm also using OpenCV in ROS Groovy and I need to use the cvblob library. I have the same linking error while compiling, just for the cvblob lib can not be found.
You should have something like this in your CMakeList.txt to link OpenCV with your pkg:
include_directories(include
 ${catkin_INCLUDE_DIRS}
 /home/elod/opencv/cmake/
add_executable(bagDetect src/main.cpp)
find_package(OpenCV REQUIRED)
target_link_libraries(bagDetect ${OpenCV_LIBS})
I'm working with ROS Groovy therefore my package.xml has this rows to:
<build_depend>OpenCV</build_depend>
<run_depend>cvBlob</run_depend>
If you build it with make VERBOSE=1, than ur able to check the linked libraries.
Originally posted by zweistein with karma: 231 on 2013-03-04
Comment by Dave Coleman on 2013-03-04:
Thanks for the answer, that's about what I did after Vincent helped me. Also, I'm pretty sure having "/home/elod/opencv/cmake/" hard coded into your CMakeLists is bad practice.
Vincent Rabaud helped me through this issue via Email:
Ok, so vision_opencv is a stack so you cannot depend on it/find_package it: you have to depend/find_package any of its packages (cv_bridge ...).
opencv2 is not a ROS package so you cannot find_package it through catkin. You need to find_package it as any user would do: find_package(OpenCV). I'll update the wiki for that.
So now in my package.xml I have:
  <build_depend>image_geometry</build_depend>
  <build_depend>cv_bridge</build_depend>
And in my CMakeLists.txt:
find_package(catkin REQUIRED COMPONENTS cv_bridge image_geometry ...)
add_executable(calibrate_kinect_checkerboard
  src/detect_calibration_pattern.cpp
  src/calibrate_kinect_checkerboard.cpp
target_link_libraries(calibrate_kinect_checkerboard ${catkin_LIBRARIES} ${OpenCV_LIBS})
Originally posted by Dave Coleman with karma: 1396 on 2013-03-04
Post score: 6
Comment by lifelonglearner on 2013-10-07:
I am facing the same problem, but this explanation seems to be a little more complicated for a beginner like me, can you please explain in a little easy way. Thanking you.
Comment by GeneralSpoonFul on 2014-01-08:
I have the same problem and I'm still facing the same problem even if I added the lines Dave Coleman said to in the package and CMakeLists files... I still can't find the cv_bridge package when using catkin_make.
