#include stdio.h> #include iostream> #include "opencv2/core/core.hpp" #include "opencv2/features2d/features2d.hpp" #include "opencv2/highgui/highgui.hpp" #include "opencv2/imgproc/imgproc.hpp" #include "opencv2/calib3d/calib3d.hpp"
using namespace cv;
int main() { Mat object = imread( "sample.jpeg", CV_LOAD_IMAGE_GRAYSCALE );
if( !object.data )
std::cout<< "Error reading object " << std::endl;
return -1;
//Detect the keypoints using SURF Detector
int minHessian = 500;
SurfFeatureDetector detector( minHessian );
std::vector<KeyPoint> kp_object;
detector.detect( object, kp_object );
//Calculate descriptors (feature vectors)
SurfDescriptorExtractor extractor;
Mat des_object;
extractor.compute( object, kp_object, des_object );
FlannBasedMatcher matcher;
VideoCapture cap(0);
namedWindow("Good Matches",0);
cvResizeWindow("Good Matches",800,800);
std::vector<Point2f> obj_corners(4);
//Get the corners from the object
obj_corners[0] = (cvPoint(0,0));
obj_corners[1] = (cvPoint(object.cols,0));
obj_corners[2] = (cvPoint(object.cols,object.rows));
obj_corners[3] = (cvPoint(0, object.rows));
char key = 'a';
int framecount = 0;
while (key != 27)
Mat frame;
cap >> frame;
if (framecount < 5)
framecount++;
continue;
Mat des_image, img_matches;
std::vector<KeyPoint> kp_image;
std::vector<vector<DMatch > > matches;
std::vector<DMatch > good_matches;
std::vector<Point2f> obj;
std::vector<Point2f> scene;
std::vector<Point2f> scene_corners(4);
Mat H;
Mat image;
cvtColor(frame, image, CV_RGB2GRAY);
detector.detect( image, kp_image );
extractor.compute( image, kp_image, des_image );
matcher.knnMatch(des_object, des_image, matches, 2);
for(int i = 0; i < min(des_image.rows-1,(int) matches.size()); i++) //THIS LOOP IS SENSITIVE TO SEGFAULTS
if((matches[i][0].distance < 0.6*(matches[i][1].distance)) && ((int) matches[i].size()<=2 && (int) matches[i].size()>0))
good_matches.push_back(matches[i][0]);
//Draw only "good" matches
// drawMatches( object, kp_object, image, kp_image, good_matches, img_matches, Scalar::all(-1), Scalar::all(-1), vector<char>(),DrawMatchesFlags::NOT_DRAW_SINGLE_POINTS);
if (good_matches.size() >= 4)
for( int i = 0; i < good_matches.size(); i++ )
//Get the keypoints from the good matches
obj.push_back( kp_object[ good_matches[i].queryIdx ].pt );
scene.push_back( kp_image[ good_matches[i].trainIdx ].pt );
H = findHomography( obj, scene, CV_RANSAC );
perspectiveTransform( obj_corners, scene_corners, H);
//Draw lines between the corners (the mapped object in the scene image )
line( image, scene_corners[0] + Point2f( object.cols, 0), scene_corners[1] + Point2f( object.cols, 0), Scalar(0, 255, 0), 4 );
line( image, scene_corners[1] + Point2f( object.cols, 0), scene_corners[2] + Point2f( object.cols, 0), Scalar( 0, 255, 0), 4 );
line( image, scene_corners[2] + Point2f( object.cols, 0), scene_corners[3] + Point2f( object.cols, 0), Scalar( 0, 255, 0), 4 );
line( image, scene_corners[3] + Point2f( object.cols, 0), scene_corners[0] + Point2f( object.cols, 0), Scalar( 0, 255, 0), 4 );
//Show detected matches
imshow( "Good Matches", image );
key = waitKey(1);
return 0;
I've a SURF code that works on OpenCV. I need to run this code on ROS. How can I do it with the help of cv_bridge?
Originally posted by Bala on ROS Answers with karma: 31 on 2013-02-27
