Hello guys,
I'm pretty new on the ROS system and I'm having some trouble when trying to convert de pointcloud in the .bag file to an external .pcd file.
Soooo what I did is the following:
-Open a first terminal raphael@ubuntu:~/Link_to_HESB/Bachelor/low_freq$ roscore The location is where my .bag files are.
Then I opend a second terminal: raphael@ubuntu:~/Link_to_HESB/Bachelor/low_freq$ rosbag info 2012-08-10-17-32-31.bag
*path: 2012-08-10-17-32-31.bag version:
2.0 duration: 3:52s (232s) start: Aug 10 2012 22:32:31.20 (1344630751.20) end: Aug 10 2012 22:36:24.18 (1344630984.18) size: 4.8 GB messages: 9127 compression: none [2326/2326 chunks] types: bond/Status [eacc84bf5d65b6777d4c50f463dfb9c8] diagnostic_msgs/DiagnosticArray [3cfbeff055e708a24c3d946a5c8139cd] rosgraph_msgs/Log [acffd30cd6b6de30f120938c17c593fb] sensor_msgs/PointCloud2 [1158d486dd51d683ce2f1be655c3c181] std_msgs/String [992ce8a1687cec8c8bd883ec73ca41d1] velodyne_msgs/VelodyneScan [50804fc9533a0e579e6322c04ae70566] topics: /diagnostics 232 msgs : diagnostic_msgs/DiagnosticArray /rosout 49 msgs : rosgraph_msgs/Log (4 connections) /septentrio/SbfAttCovEuler_1_0 233 msgs : std_msgs/String
        /septentrio/SbfAttEuler_1_0             233 msgs    : std_msgs/String
        /septentrio/SbfBaseLine_1_0             233 msgs    : std_msgs/String
        /septentrio/SbfBaseVectorGeod_1_0       233 msgs    : std_msgs/String
        /septentrio/SbfDOP_2                  233 msgs    : std_msgs/String
        /septentrio/SbfEndOfAtt_1_0             233 msgs    : std_msgs/String
        /septentrio/SbfEndOfPVT_1_0             233 msgs    : std_msgs/String
        /septentrio/SbfGeoCorrections_1_0       233 msgs    : std_msgs/String
        /septentrio/SbfPVTGeodetic_2_1          233 msgs    : std_msgs/String
        /septentrio/SbfPVTResiduals_2_1         233 msgs    : std_msgs/String
        /septentrio/SbfPosCovGeodetic_1_0       233 msgs    : std_msgs/String
        /septentrio/SbfPvtSatCartesian_1_0      233 msgs    : std_msgs/String
        /septentrio/SbfRAIMStatistics_2_0       233 msgs    : std_msgs/String
        /septentrio/SbfVelCovGeodetic_1_0       233 msgs    : std_msgs/String
        /velodyne_nodelet_manager/bond          932 msgs    : bond/Status               (3 connections)
        /velodyne_packets                    2326 msgs    :    velodyne_msgs/VelodyneScan
        /velodyne_points                     2326 msgs    :    sensor_msgs/PointCloud2*
Soo then what I do is that I try to extract the /velodyne_points but is doesn't work:
*raphael@ubuntu:~/Link_to_HESB/Bachelor/low_freq$ rosrun pcl_ros bag_to_pcd 2012-08-10-17-32-31.bag /velodyne_points ./pointclouds Saving recorded sensor_msgs::PointCloud2 messages on topic /velodyne_points to ./pointclouds
ERROR 1361880690.779414125: Frame id /base_link does not exist! Frames (1):
Erreur de segmentation (core dumped)*
So I found some informations about changing a TF file but I'm really new on ROS & Ubuntu so I have no clue where & how I actually should do this ;)
Can someone here help me on this? I already lost some hours trying to solve that ;)
Originally posted by Dexter111 on ROS Answers with karma: 86 on 2013-02-26
Thanks for your answer!
Sooo the bag file wasn't done by myself & the people who generated it are far far away ;)
So I ran the bag: rosbag play 2012-08-10-17-32-31.bag
And in an other terminal I displayed the list of the working topics:
rostopic list /clock /diagnostics /rosout /rosout_agg /septentrio/SbfAttCovEuler_1_0 /septentrio/SbfAttEuler_1_0 /septentrio/SbfBaseLine_1_0 /septentrio/SbfBaseVectorGeod_1_0 /septentrio/SbfDOP_2 /septentrio/SbfEndOfAtt_1_0 /septentrio/SbfEndOfPVT_1_0 /septentrio/SbfGeoCorrections_1_0 /septentrio/SbfPVTGeodetic_2_1 /septentrio/SbfPVTResiduals_2_1 /septentrio/SbfPosCovGeodetic_1_0 /septentrio/SbfPvtSatCartesian_1_0 /septentrio/SbfRAIMStatistics_2_0 /septentrio/SbfVelCovGeodetic_1_0 /tf /velodyne_nodelet_manager/bond /velodyne_packets /velodyne_points
Sooo everything looks fine
Then I did what is proposed in the question #33072: rosrun pcl_ros pointcloud_to_pcd input:=/velodyne_points
And, magicaly, I became all the PCD file I needed! Thanks again for your answer!
Originally posted by Dexter111 with karma: 86 on 2013-02-26
Comment by ayush_dewan on 2013-02-26:
ok cool...
Comment by Dexter111 on 2013-02-26:
I guess the bag_to_pcd function is still not completely working for those situations, and pointcloud_to_pcd do pretty much the same but is working proprely ;)
