I am aware that ros uses the positive coordinate system in which x=forward, y=left, and z=up, but can anyone tell me what pcl data uses?
Originally posted by ee.cornwell on ROS Answers with karma: 108 on 2013-02-21
Comment by ee.cornwell on 2013-02-22:
joq, that's what I thought until I used the function pcl::fromROSMsg() and a pcl passthrough filter. The PCL z parameter pertained to forward direction and y pertainted to the upward direction. I'm speaking in terms of the pcl namespace. Is this correct?
Comment by joq on 2013-02-23:
Check the header.frame_id field in the message. It may be using an "optical" frame by mistake. See: http://www.ros.org/reps/rep-0103.html#coordinate-frame-conventions
Comment by ee.cornwell on 2013-02-23:
Thanks for the help!
The same, in whatever frame of reference the PointCloud2 message specifies.
Originally posted by joq with karma: 25443 on 2013-02-22
