I'm trying to use the openni_launch and openni_tracker packages. I made a package called kinect_hmi and a launch file which launches both the openni_launch file and openni_track. When I tested this previously I could view he PointCloud2 data and the tf data in RVIZ. However, today when I started up the code I get the following error.
Error opening database/parameters file.
The point cloud data still shows up in RVIZ, but the skeleton tracking does not seem to be working. I tried starting roscore, openni_launch, and openni_tracker separately to see if my launch file was the problem but it didn't help. I have no idea why it isn't working all of the sudden.
Just in case here is my launch file
<launch>
  <include file="$(find kinect_hmi)/launch/camera_topics.launch" />
  <node pkg="tf" type="static_transform_publisher" name="depth_to_camera_broadcaster" args="0 0 0 0 0 0 camera_link openni_depth_frame 100" />
  <node name="openni_tracker" pkg="openni_tracker" type="openni_tracker" respawn="true"/>
</launch>
The camera topics launch file is the following
<launch>
  <include file="$(find openni_launch)/launch/openni.launch" />
</launch>
I thought maybe that the parameter server wasn't running so I tried the rosparam list command. However, the command returns a long list of things so I'm assuming that the parameter server is running.
My question is: Why is this happening and how do I fix it?
Thanks in advance
Originally posted by rhololkeolke on ROS Answers with karma: 15 on 2013-02-21
Comment by Josch on 2013-03-04:
Have you tried reinstalling the openni package? Maybe you can just start install.sh again.
Hello. I have same problem, but i managed to fix it. Problem is in primesense library. Some file don't have privileges. U need go to:
/usr/etc/primesense/Features_1_5_2
and set privileges to folder Data. I did it through nautilus and my problem was fixed.
Hope it will help you too.
Originally posted by PNowak with karma: 26 on 2013-03-15
Comment by rhololkeolke on 2013-03-20:
The system I'm developing on is erased each reboot. Unfortunately I rebooted before I could test this solution, but because rebooting (which would reset all file permissions to when they were working) fixed the problem I'm accepting this answer as correct.
Comment by jarvisschultz on 2015-11-06:
This answer fixed my error. Strange, I've been using the NITE packages for a long time, and I've never seen this error before. I wonder what caused it?
