Hi,
I have been trying to install ROS Groovy Mobile on my RPi. I keep getting an error when I run sudo rosdep install --from-paths src --ignore-src --rosdistro groovy -y which returns ERROR: the following rosdeps failed to install apt: command [sudo apt-get install -y python-rospkg] failed
Any ideas how to get around this? I cannot install the package at all. I commented out the dependency in roslib.
Anyone have an image of ROS Groovy Mobile or Full installed on Raspbian?
Originally posted by tonybaltovski on ROS Answers with karma: 2549 on 2013-02-19
good news, there is exactly what you ask for
push this link hard!
Have fun with it :)
Originally posted by kalectro with karma: 1554 on 2013-02-19
Comment by tonybaltovski on 2013-02-20:
That was the guide I was using. I cannot get past 5.6 due to the error above. Were you able to install it?
Comment by kalectro on 2013-02-20:
Yes and I also posted an image file on the very top of the tutorial ;) There is a red box right under the command which tells you that this command will fail and how to fix it
Sorry I did not notice the link. Thank you so much for that. I edited many package.xml that contained python-rospkg but it still fails. I will try the image now. Thank you again. I'd still like to be able to install from source but I'll try that in my spare time.
I added the robust option for rosdep (-r) which should give you a summary of all packages which have not been installed successfully at the end. If there is no ERROR and only some apt-get commands which were not found, you will be fine and can go on with the tutorial. Feel free to edit it as well
Comment by tonybaltovski on 2013-02-21:
Thank you. I just tried the image and it works perfectly. I will try to compile it from source another time. Your help with much appreciated.
Comment by tonybaltovski on 2013-02-23:
@kalectro Do you use the RPi as the master or another laptop? I configured my laptop as the masters for my RPi. I can see the rostopic list but I cannot echo any topics. When I try to use a simple command to publish such as rostopic pub /test std_msgs/Int32 300, I can see it locally on the PRi.
Any ideas? (Sorry I ran out of characters)
Comment by kalectro on 2013-02-23:
It will also work with a master running somewhere else. The issue you have might be due to your DNS. Try setting ROS_IP, that should work
Comment by tonybaltovski on 2013-02-24:
I set the ROS_IP in the .bashrc but it still does not work. I can see the topic but cannot echo it. Do I need to run any commands after I write the image to the SD to initialize ROS?
Comment by kalectro on 2013-02-24:
no, ROS should work out of the box. Did you set ROS_IP on the raspberry pi and the laptop? I would not recommend setting it in the bashrc file because the address could change. Just to be clear... set ROS_IP to the IP of the respective device. Find it out using ifconfig
Comment by tonybaltovski on 2013-02-25:
I set the ROS_IP correctly and I confirmed by echo $ROS_IP. I set it in the bashrc since all my interfaces are static for now. The communication is there between the two but the RPi can publish or echo topics but I can see the topics even new ones created on the master laptop.
Do you use the GUI on this image? I cannot get the USB devices to work once I boot the GUI using startx but once I use a original image they work fine.
Comment by kalectro on 2013-02-25:
no, I did not try any gui on the Raspi
Comment by tonybaltovski on 2013-02-27:
@kalectro I saw your post on the Raspi forum and thought maybe something could be corrupt with the image I downloaded. Do you mind posting the md5sum for the image? By the way, did you compile all the ROS stuff for the Raspi yourself?
Comment by kalectro on 2013-02-28:
I do not have the original image on my computer anymore, sorry. What you could try is downloading my previously uploaded image from here http://goo.gl/0yoT8 And yes, I compiled everything from source using a chroot environment. I wrote everything down in the wiki
Comment by tonybaltovski on 2013-02-28:
Thanks Kalectro, it worked. I just needed to at my master as a host in /etc/hosts with that last image. Thanks for doing all the work of compiling everything and posting the image. In addition, thank you for all your help.
