I'm currently doing some experiments with fovis_ros and a kinect . This works pretty well, but fovis uses an other type of coordinate frames where +X is to the right, +Y is down and +Z is forward. The thing is that none of the camera views in RViz are able to let the camera rotate around the Y axis instead of the X axis. This makes it kinda hard to get a nice view in RViz. It seems that RViz was only made for the coordinate frame conventions documented on this page: ros.org/wiki/geometry/CoordinateFrameConventions
Any of you guys encountered the same problem? Is there anyone with a solution for this problem?
Originally posted by Robbiepr1 on ROS Answers with karma: 143 on 2013-02-18
3 Answers 3
Depending on the launch file you use for your kinect, it might be that there is already a static_transform_publisher running that publishes a tf between camera_link and camera_rgb_optical_frame. You can check that easily by running
rosrun tf tf_monitor
If you want, you can easily give this camera_rgb_optical_frame as base link frame id to fovis_ros:
rosrun fovis_ros stereo_odometer _base_link_frame_id:=/camera_rgb_optical_frame
fovis_ros will then publish movements through tf and odometry messages using /odom as fixed frame and /camera_rgb_optical_frame as the moving (child) frame. If you set the fixed frame in rviz to /odom you should see the camera frames moving while moving the kinect.
Originally posted by Stephan with karma: 1924 on 2013-02-18
Comment by Robbiepr1 on 2013-02-18:
Thanks! That did the trick for now. Although it would be nice if there was some kind of setting in RViz itself.
This is the standard camera optical coordinate system.
The easiest solution I see to your problem is to publish a transform between the camera system and the camera's optical system, e.g. by using a tf static_transform_publisher.
Then select that system in rviz instead of the optical on that, you have now.
Originally posted by dornhege with karma: 31395 on 2013-02-18
Switching the up axis might be a useful feature in RViz. You're welcome to open a feature request ticket on https://github.com/ros-visualization/rviz/issues
Comment by Stephan on 2013-02-18:
+1! Especially for underwater robotics, where the standard coordinate system is NED (North East Down).
This would be a nice feature indeed. I will open a feature request on github
Comment by dgossow on 2013-02-19:
After reviewing this I would say that this is a likely feature for a future RViz release.
For further comments on the feature request please use the github tracker: https://github.com/ros-visualization/rviz/issues/597
