Hi ,
I am just trying to install openni_launch and openni_camera to get my asus xtion pro live to work.
I have ubuntu 12.04 and fuerte. when I type
rosdep install openni_camera
sai@sai-HP-EliteBook-8460w:~/fuerte_workspace$ rosdep install openni_camera executing command [sudo apt-get install libopenni-dev] Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: libopenni-dev : Depends: libopenni0 (= 1.5.4.0-4+precise1) but it is not going to be installed E: Unable to correct problems, you have held broken packages. ERROR: the following rosdeps failed to install apt: command [sudo apt-get install libopenni-dev] failed
Originally posted by sai on ROS Answers with karma: 1935 on 2013-02-13
How i solved was,
I removed ps-engine from ubuntu software center and then i was able to do rosdep and install dependencies.
This has occurred because I had pcl libraries installed before and some dependency conflict might have occured
Originally posted by sai with karma: 1935 on 2013-02-13
